Haha, I need to print myself some glasses frames !! lol
My first print in Bronzefill, tried various polishing techniques but settled for fine grain sand paper (240 grit), rotating brass wire brush with a dremel on low speed and finally Autosol polishing paste with a rag.
The aged look is accomplished with applying a layer of black spraypaint and instantly afterwards try to wipe as much paint as possible off with a rag, this is done right before the final polishing.
Wow, looks awesome!
It totally looks like something several hundred years old you found in some ancient ruins :mrgreen: very cool. The more i see bronzefill prints the more i'm eager to buy some
@Meduza (or do I have to write 'CAPTAIN Meduza'...?): You should really put it back into that treasure chest... otherwise you might be a bit surprised to see yourself in moon light... :eek:
But really cool! :cool:
@ Meduza Oh wow awesome print and post work, looks so effin realistic.
Targeter - fantastic print!
What is not printed in this model? Would love to try and print it myself.
The tracks are assembled by 1x15mm nails
The axles for all wheels and rollers are either 3.3mm or 1.6mm stainless welding rod
M3 bolts and nuts for the turret
Lots of loctite precision glue :wink:
@Didier.. haha Great video! Is that your wife, girlfriend? How did a geek like you catch such a pretty thing
@Targeter Cool little models, how many parts per the tank?
Im not sure of the exact parts count, the tracks are like 180 links or so each, and the tank itself is 40-50 individual parts.
@Meduza Awesome mate!
Thanks, i really love how it came out, this filament behaved just as good as i hoped it would to buffing and aging, it is very cool since i could hand this print to people and most of them can not tell that it was 3D printed.
Seen a dozen times but imo the obliged print for testing filaflex:
Cute octopus says hello:
My very first filaflex print. Thanks to Robert for his awesome feeder
Nice! Only very few under extrusion. What type of flex filament is this?
Filaflex
Printed at 235º/60º.
0.1mm layers, 30mm/sec.
When printing the bottom I noticed some underextrusion so I upped the flow to 102% and the speed to 90% (so actually it printed at +27mm/sec)
My sculptures prints in overview
And my actual print.
200mm in Z
Layer 0.1
Shell 0.8
Bottom 0.6
Infill 5%
Speed 50mm/s
Really nice quality with 0.1mm layer. Only the supports removed, no finishing.
wow cool stuff dirk, thanks for the numbers, will give them a try one day
i love this.. is is the simple moment where i do admit to myself.. why did i never think of something that simply and brilliant.
really love it !!!
Ian :-)
I bought it at trideus (belgian store) in case that is of interest. Haven't seen bronzefill yet there, which I want to try, but preferably when I manage to somehow come by a bigger nozzle
This is my latest print. My Nephew loves coca cola memorabilia, so I decided to make him a sign. I think I will paint it before I give it to him. I'll try to post pics after I paint it.
Hi Guys,
Been a long time since I didn´t post anything here, so I decided to do this...
Sorry, but I forgot to take pictures before painting... :mrgreen:
Cheers
@Travis Pretty cool!
Did you extract the logo from an image or recreated it? If you did, what do you use for generating your mesh?
I know there are a few options but that looks pretty clean.
I finally got a chance to test out a first filament of Faberdashery from a dozen of 10-20m samples I ordered the other day. Printed out like a charm.
Like some would say:
It prints like butter
So I made a little something for my daughter. Go some pony on Thingiverse.
I made the supports in Meshmixer and saved 30 minutes of printing (and no it didnt take me 30 min to do them )
removing support left some marks
So I thought of Skint that soldered 2 filaments together to finish a print and used my soldering iron to simply smooth the surface a bit while it was heating up and got them almost completely out. Its the first time I try this and it worked pretty nicely.
@pm_dude I use a really simple 5 step process. I know 5 steps sounds like a lot, but it's a fast, simple and clean way to make a mesh from a logo and print it. I use illustrator and 3ds Max. Other modeling packages might be compatible with illustrator files, but I'm not sure.
1. I start with finding a nice high res jpg image of the desired logo I want. This works best with uncomplicated logos like the coca cola one. Lower res images work ok too, but I try to find the highest resolution so I don't have to clean up the logo in illustrator or max.
2. Next I open up the file in illustrator, click on the image once and live trace will appear at the top. Hit the live trace button once. There are settings you can mess with while using live trace, but I always just use the default. With a high res image, the default settings usually outline the logo flawlessly.
3. Save the image as and .ai file, but make sure to use legacy and select illustrator 8. I have found this works the best for importing into max.
4. Import the illustrator file into 3ds max. You now have a flat spline that you can ad an extrude modifier to.
5. Once you extrude your logo in max , you can export as an .stl file or further edit it in max i.e. adding a back to a logo that has letters that would fall apart when printing.
6...I think all of us know what to do with the .stl file next lol.
I use this as a simple way to make fun prints to give to people. I love printing these because they end up being flat and thus unlikely to fail as easily. Also since the process is so easy, I can be printing almost almost any logo I want within a few minutes.
Cool I use max a lot but I never used illustrator. Makes total sense!
Thanks for sharing
Top Posters In This Topic
362
275
221
175
Popular Days
Jan 5
30
May 12
26
Jan 13
23
May 1
22
ian 362 posts
cloakfiend 275 posts
skint 221 posts
SandervG 175 posts
Popular Days
Jan 5 2014
May 12 2014
Jan 13 2014
May 1 2014
Popular Posts
kmanstudios
Took me forever to do this. And it is still rougher than I would have liked. 3D concept rendering: Finished piece:
kmanstudios
I just finished this. It was a multi-part print for ease of painting. Some of it I am not sure what happened...but hey, it is purty....And, I am unanimous in that ? Test Render Parts
gr5
Bath interferometers. I have made about 20 of these for people who use them to test their telescope mirrors. They are amazingly accurate and can do better than a $40,000 Zygo PSI optical tester. Th
Posted Images
DidierKlein 726
@skint No it's my sister in law ^^ but my wife is as goodlooking :mrgreen: (she has 3 sisters all good looking) it's my printed glass frames that make all the girls go wild
