Voids being filled by cura
Go to solution Solved by Slashee_the_Cow,
Posted · Voids being filled by cura
Hi there, i have sliced my stl and for some reason it filling in the void. Thankfully i noticed on the first layer of the print as i had not checked the preview. There are voids on the top and bottom of the stl and if i turn the stl 90 degrees both voids will get support as usual. I fi tun it over 180 degrees the voids will get filled again. Any thoughts? this is the first time i have come across this in hundreds of prints.
    • Solution
    Make sure Mesh Fixes > Remove All Holes is turned off.
    If that's not it, if you could post the Cura project file (.3mf, get it set up then go to File > Save Project) that's more help than just the model file since it contains your print settings.
          • Heart
        • 7 replies
