(notice: The first Sample should be ignored, it was a normal (non printed) plastic probe, so my first sample starts with number 2)
So what you can see is that with lower Temp the strength goes down. No big suprise.
But the last Sample with 260°C and 110% got a very good improvement on the breaking elongation.
Under the microscope you can see that the infill did not really melted together. While the two outer lines were much stronger. So it looks like i need to go up with the flow rate.
Its funny because with the eyes only, it looks almost over extruded, but under the microscope you could see that the lines are not always touching each other.
Also under the microscope the outer lines didn't look different at 100% flow or 110% flow. Witch means going up with the flow rate should not affect print quality that much.
Here are the pictures of the broken surface. The whiter the surface is, the more deformation it gets before it did break.
So you can see all three 100% flow rate samples have very bad sticking on the infill, but quite good sticking on the outerlines. Even the sample with 110% flow rate still got not a perfect infill.
I will try to do some other tests with lower speed, more flow, and thinner nozzle size in cura soon.
jonask 0
Hello, today i also did some strength tests in my university and i want to share the results with you.
I tested Black abs http://www.conrad.de/ce/de/product/555893/3D-Drucker-Filament-Velleman-ABS3B1-ABS-Kunststoff-3-mm-Schwarz-1-kg/SHOP_AREA_857889?
I printed the 1BA.stl from here http://www.thingiverse.com/thing:190386/#files
all parts were printed flat on the build plate.
I tested 4 samples.
Print parameters:
All speeds: 50mm/s
100 %infill
0.8shell
1 sample: 260°C 100% infill
2 sample: 250°C 100% infill
3 sample: 240°C 100% infill
4 sample: 260°C 110% infill
Diagrams:
