Change the end position
Go to solution Solved by GregValiant,
Posted · Change the end position
I currently own a Mingda Magician Pro 2 and i want to change the position at which the bed goes after the print finishes, since i want the bed to slide forwards for easier removal. Sadly I have tried messing around in the end G-code mashine settings, but for some reason it (extruder) always first goes forwards before very very slowly pushing the bed forwards. I am wondering if someone knows of a way to have the printer go to the desired location directly. Btw, here ist the original end G-code for reference:
M104 S0
M140 S0
;Retract the filament
G92 E1
G1 E-1 F300
G28 X0 Y0
M84
    • Solution
    Posted (edited) · Change the end position
    This is what I use.  It retracts, slides to the side, moves up, and then the bed goes to max Y before shutting everything off.
    Cura uses "replacement patterns" that are essentially variable names.  When the project is sliced, Cura will replace the words with their values.  Speeds from Cura are in mm/sec but the gcode uses mm/minute so each speed must be multiplied by 60.
    The line in bold is really the one you asked for.  If it's all you want then it would replace your G28 X0 Y0 line.  If the Z doesn't go up a little bit first your nozzle could drag on the top surface of the print.
    ;-----------------Ending Gcode
    G91               ; Relative positioning
    M83               ; Relative Extrusion
    G1 F{retraction_retract_speed*60} E-{retraction_amount}      ; Retract
    G0 F{speed_z_hop*60} Z0.2 ; Raise Z
    G0 F{speed_travel*60} X5 Y5    ; Wipe out
    G0 F{speed_z_hop*60} Z10        ; Raise Z more
    G90               ; Absolute positioning
    M82               ; Absolute extrusion
    M220 S100         ; Reset FeedRate
    M221 S100         ; Reset FlowRate
    G0 F{speed_travel*60} X0 Y{machine_depth}        ; Present print
    M106 S0           ; Turn-off fan
    M104 S0           ; Turn-off hotend
    M140 S0           ; Turn-off bed
    M84 X Y E         ; Disable all steppers but Z
    ;-----------------End of Ending
    Edited by GregValiant
          • Heart
        • 7 replies
