The left side issue is probably unrelated. I mean it's possible the bed moves most of the way initially and then very slowly slides farther down over the next 5 seconds but I seriously doubt it.
The side issue is probably related to your model shape or that's maybe where your z-seam is and it's just exacerbating the issue. Make sure "retract on layer change" is disabled as that can make the initial printing on a new layer underextrude. Also maybe look at PREPARE mode and play through a known "bad layer" and watch the first few seconds of how it starts printing the outermost layer - what happens just before (does it print infill just before? inner wall just before?). Make sure there are no retractions or long distance moves or speed changes when it starts the outermost wall.
- 1
gr5 2,265
If the Z axis moves slightly too far then that layer will be underextruded because the gap to be filled is bigger than expected and not enough filament is coming out of the nozzle. So the layer will stick inwards a bit.
If the Z axis moves slightly less than desired then similarly, the layer will be slightly overextruded and will stick out a bit.
Usually the Z axis is calibrated perfectly long term but each individual layer sees small errors that are recoverred on either the next layer or certainly within a few layers but you get this horizontal banding that I see on your print.
1) The easiest fix is to do thicker layer lines. If you double the thickness of the layers then the error will be a smaller percentage of the total movement of a layer so you get correspondingly smaller amounts of over/under extrusion.
2) Another fix is to clean your Z screw very very well. Your parts actually look quite good so to improve them you really have to remove the Z axis (I think it's pretty easy - just 4 screws under the printer but you have to also unplug the Z servo so more screws to remove the bottom cover - careful, if you have an S5R1 (versus S5R2) there are deadly voltages so unplug the printer if you remove the bottom cover. Once the 4 screws are removed the stepper motor and Z screw slide out the bottom of the printer. Put it over newspaper.
Whether you take it out or not, clean with WD40 and a toothbrush - remember it's a triple helix so make sure the toothbrush gets into all 3 independent threads. Remove all grease and oils, then dry, then regrease with one pea sized drop of grease and no more. Concentrate on the thread farthest from the motor since you are printing "small" parts.
3) Placing a heavy weight such as a brick or lead weight at the back of the bed near where the screw passes through sometimes also helps get the layer heights consistent but do this after the leveling process is complete!
TEFletcherr 0
@gr5
Thank you so much for the detailed response! The explanations for under/over extrusion based on the Z-axis movement make a lot of sense, especially when I think about how it could contribute to the horizontal banding I'm seeing. I really appreciate the breakdown of potential solutions.
It’s interesting because the inconsistent layer lines really do seem concentrated on the left side of each wall. Could an uneven or slightly misaligned Z-axis also create more issues on one side than the other?
Cleaning the Z-screw was one of the last things on my list to tackle since it seemed like a big project. But your instructions definitely make the process feel a bit more approachable!
Thanks again for all the advice!
