Posted (edited) · one support layer of 0.2mm not working
Hello everyone,
I'm trying to print just a single layer of support at 0.2mm.
It only works if I adjust my model to a clearance of 0.4mm, but I want as little clearance as possible around my print.
Current Settings:
  • Support Z Distance: 0mm
  • Z overrides X/Y (just in case)
  • Support infill layer thickness: 0.2mm
  • Minimum support area: 0.0mm²
I've tried dozens of different settings, but I can't seem to get it right.
Is it possible to print a single layer of 0.2mm support with Cura, and if so, how?
Thanks in advance for your feedback!
Edited by Grorkel
    Load the model, set Cura up to slice, and use the "File | Save Project" command to create a project file.  Post that 3mf file here and someone will take a look.
    I didn't have any trouble generating .2mm support with the model I used.  The gap has to be over 0.20 and it must be at a height that is being hit by a slice.  If the top of the surface is at a number like "10.35" then it just might be getting ignored as it might not be "within" a layer.
    Edited by GregValiant
          • Heart
        • 4 replies
