GregValiant 1,488
I just printed an oval handle and the print time was seriously impacted by "Scarf Seam". Speeds were down as low as 2mm/sec. At a set print speed for all features of 50mm/sec, the average speed (of just the extrusions) was 24.5mm/sec. That's a pretty big hit.
On the other hand, the seam came out really good. "If ya wanna dance you gotta pay the piper."
Here is the Zseam on that handle.
Edited by GregValiant-
1
GregValiant 1,488
I've printed a lot of threads. Since your models are all about the threads I would suggest going to a 0.10 layer height.
I will assume that you are using a standard thread form with an included angle of 60°. The absolute maximum "overhang angle without support" is 63° so you are very close to that. In addition, since the previous layer is inset from the current layer (no real support for it) when the nozzle makes it's shuffle over to start the outer-wall - oozing pushes a little material out and down. Add that to the lack of any support and you get the blob. A lower layer height will help support the area of the blob and and the blob should be more of a zit.
Regardless of the material, you might want to insure you have some decent layer cooling as well. You'll be bouncing off the Minimum Layer Time and cooling that feather edge of the threads could be a key.
I ended up altering the thread form (for printed threads) and changing the included angle to 70°. That allows the previous layer to provide a little more "shoulder" so the start of the next layer is better supported. It isn't perfect, but it works for me.
I had high hopes for the new Scarf Seam when printing threads but so far as I've tested, it hasn't provided the big bang that I had hoped for. It may just be a matter of dialing it in better....or a snake oil salesman put one over on somebody.
I see you are using a little bit of "coasting". I'm not a fan of "Coasting" for anything other than large flat skins. It tends to bounce the nozzle pressure up and down. That can make dialing in other settings harder to do.
Finally, there are no corners on the threads to hide the seam at so I would set the "Seam Corner Preference" to None.
Slashee_the_Cow 619
Some settings of note:
For PLA on a printer with a Bowden extruder such as yours, the retraction distance should be about 6mm and the speed about 45mm/s.
Even leaving it as cubic but turning the density up to 20% gives you much more internal structure:
There's no point trying to save filament if your result is so weak it's just going to break and you need to print the stronger version anyway.
PETG is a little bit of a pain to work with a lot more of a pain to store (as it absorbs moisture from the air so you either need to store it with desiccant or dry it before your print it if it's been a few days since you last dried it) but it's a little bit flexible and less likely to snap with force applied to it. I can vouch for this personally since I've printed a couple of tripod plates for cameras - and in the end I just bought some 1/4" screws, cut the heads off and glued the threaded bits into the plate (but PETG still worked better for the plate as it will sustain force when you're screwing it into something).
extrusion > retraction, my brain hurts
CodeFalcon 0
@GregValiant, @Slashee_the_Cow,
Thanks both for your responses, they both contain a lot of useful information. Turning off coasting and reducing the layer height helped a lot.
@Slashee_the_Cow I agree; my material choice and model aren't great for this application. It was more of a test print to dial-in settings for printing threads on my printer. Disabling Travel > Retract at Layer Change and increasing the bed temperature to 60 helped a lot. Thank you for pointing out the Material > Vertical Scaling Shrinkage Compensation. I am not sure why that wasn't set to 100%. I am not sure I understand what you mean by Extrusion Distance or Extrusion Speed. It was my understanding that Cura would calculate these based on the filament diameter, the intended line width and the layer height.
I have attached a new project file with my new settings. Here is the newly printed result:
I am very pleased. All the blobs are gone and unless you specifically look for it, you can't see the seam either.
My last question is, for test prints and prototypes, is there any way to speed the print up without causing blobs, as this print now takes much longer?
Nut_and_Bolt.3mf
