Both methods work, but there is a problem with the thumb wheel underneath the buildplate at the rear of the machine. When you repeat the procedure with that rear screw multiple times, then after each procedure, the build plate will rise a little bit further. There is no step in the procedure for tightening the rear screw. Eventually, the back of the build plate will rise so far that it either puts stress on the electric wires to the build plate, or it moves the build plate outside the allowed tension range for automatic bed levelling (40mm if I remember correctly).
I remember we changed the procedure to use the front knob instead of the rear screw, but it looks like this was not updated everywere (or the knowledge got lost).
So, choose the method that suits you best, but when using the rear screw make sure to add a first step where you tighten it a bit.
ahoeben 2,047
The idea is to first do a rough leveling with all three screws, and then do another pass with the same screws to do finetuning. If your bed is very unleveled, and you start to fine-tune one screw, going to the next screw will affect the finetuning you did on the first screw. By doing a rough pass over each screw first you mitigate that issue, but it can be worth it to do multiple finetuning passes with each screw in turn.
