Hi @giugni,
Thanks for sharing the project file. 💪
I took a look and it seems that the infill through wall is caused by your Connect Infill Lines setting. If you disable it, you'll see that the infill is not going through the wall anymore.
Your problem with the randomness is really puzzling me. I'll bring it up to the team to see what they can do to improve it. But I expect that if it's not a quick fix it will not get a high priority to implement.
So, fingers crossed 🤞
- 1
MariMakes 206
Hey @giugni,
I moved your topic out of the release thread, because that makes it easier to troubleshoot your bug.
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
giugni 2
Thank you for opening a thread for me,
attached is the project file
i saw two problems:
- the infill going throgh wall
- the outer and inner wall seams are not random but in the "same area"
test 5.9.3mf
