14 minutes ago, gr5 said:So they make you slice the model and they print it? I never heard of that before. Usually you send them the STL and they slice it.
When cad exports, fewer triangles is certainly better. So the left one is definitely better. It will slice faster as well. Typically there is an option in the CAD that lets you set things that define how many lines to use on a curve. Maybe it's called resolution. I don't know what's best but I'd go no smaller than 0.1mm.
Thanks. I was told my model had "bad mesh" - but they did not explain what that means. The attached examples were given to me by someone explaining what it is, but do not know why mine was bad - maybe I had too many rounded surfaces instead of polygonal because that makes too many smaller triangles?
gr5 2,265
