Well there are many out there that work just fine. I tried to assist. Sorry, pal.
- 1
Don't bother with the 1mm calibration--do both passes at the paper height distance instead. Is it possible you've got the wrong side of the glass facing up after cleaning? It really should just work. Do you have the active leveling running before every print?
LePaul 354
Have you tried this tutorial?
urbanshark 3
Yes, thanks for the tip, but this is useless. I’ve already spent 2 days trying to adjust the distances between the left and right screws and the rear side, but without success. A 1mm difference between the left and right sides and my print is ruined, over and over again. And there’s only manual calibration, which just tells you to focus on your 'feeling' when calibrating. The creator claims it's for professionals? Who made this printer, a clown? I strongly do not recommend this printer to anyone!!!
