So, if I understand correctly, make a filament change at layer 11, back out to the "modify G code" option, select the next layer change, so on and so on?
Or do I have to go all the way back to the "extensions" tab and start over from there?
Now that I know it's possible, I'm just looking for clarity on how to actually accomplish this.
Thanks.
Slashee_the_Cow 619
Just use the dropdown on the left to select the same script again. You can have multiple instances of the same script.
