Might also be useful to know what material it is, exactly. Different materials adhere differently to the build plate.
With PLA I personally never require a glue stick, while with TPU95A there's a 50/50 chance that my print will look the same as OP's if I don't use one.
Edited by PizzaTijd
gr5 2,267
I'd love to see a photo of the first layer just as it's half way done printing.
Also please post your project file. In cura do "file" "save project" and post that file here. It will contain your STL and how you placed it. I'm concerned that this model doesn't have a lot of contact with the glass bed so you may need more brim than usual. I want to see what you chose for support. This model is a little difficult as it doesn't sit flat on the bed. May I suggest the "cute octopus says hello" or squirtle as a cute animal first print.
Did you use gluestick? These printers come with gluestick to put on the glass bed.
Did you do the manual leveling step? You want good squish on that first layer so maybe turn the 3 screws an identical amount to move the bed up. Maybe 1/4 turn? I'd have to see your first layer.
