@GregValiant Thanks, I managed o open the DIN connector and the pins were not wired the way I thought. I soldered some new wires to the pins and the shield and everything is working now.
- 1
Congratulations figuring it out.
GregValiant 1,436
The image leaves me with a couple of questions.
Where do the "Voltage In" lines connect?
Did you pick the correct "Voltage Out" pins on the DIN connector? (The ground may be the shield.)
Is the "Voltage In" selector switch on the power supply set to your input voltage?
