6 hours ago, aramphantom said:@GregValiant Making the floor thicker would actually solve all of my problems, since the noodle structure must not change position, but still needs to be attached to the floor. May I ask how you made the floor thicker?
Kind regards!
I'm not Greg, but I'm going to assume he increased Top/Bottom > Bottom Thickness (or set a number of Bottom Layers manually). If his screenshot is from layer 11 then he's probably made it at least 11 layers thick 🙂
- 1
GregValiant 1,436
Most of this appears to be that the noodles on the inside don't all hit the floor on the inside.
This is in MS 3D Builder. The orange ones look OK but the yellow ones don't rest on the floor. The size of the gaps varies from about 0.3mm to 0.7mm. If that's the way you want it, then yes, it needs support.
It looks like Cura is slicing the model correctly. With Supports enabled in the preview, it looks like this.
I'm not sure what you are trying to do here, but it seems you have an odd combination of settings for this model as well.
For example:
It seems that if the floor of the model was thicker then the noodles would all touch the floor and supports could be turned off. If you need those gaps then changing the Support Z Gap to 0.0 and the Minimum Support Area and Minimum Support Interface Area to 0.0 would put supports under each noodle.
This is with a thicker floor and all the noodles are attached and supports are turned off. For this model this is layer 11.
aramphantom 2
Kind regards!
