24 minutes ago, Slashee_the_Cow said:Unless your startup gcode manually specifies to use the same layer height as the print, it will be inserted as is. It's not a problem in the slightest and won't affect anything about your prints.
but it doesn't specify using the same layer height as the print, but it is. even tho the gcode isn't changing, the print starting height is changing with varying layer heights
Slashee_the_Cow 541
