4 hours ago, GregValiant said:Setting the "Initial Layer Flow" is in the Material Settings. Setting that to 150% would make for a REALLY WIDE LINES throughout the first layer. That would make them stick out farther from the model.
I set Quality > Initial Layer Line Width to 150% for that. It's still higher flow, and that's what counts for adhesion. And yeah, the lines are wide. So what?
4 hours ago, GregValiant said:(I level with a piece of paper so I like the Initial Layer Flow a tad high to insure good adhesion.)
I level using my printer's automatic bed levelling because it has exactly zero manual adjustment.
That doesn't mean the ABL gets it right 😕
GregValiant 1,454
Normally the setting used is in the Walls settings and is "Initial Layer Horizontal Expansion". A setting of "-0.1" is a good place to start.
