Hi Slashee,
Thank you for the reply
Hereby the .3mf files. Also from another part where I had the wall problem. When checking if it was the correct model it opened with Cura 5.7.0. I have a few more models with the same issue but I think this is a good start to check.
354_0145346 02 TPU Red Break 4h 54m.3mf 347_0148166 - kopie.3mf 358_cad-1033304 02 TPU Black Break 4h 51m.3mf
Slashee_the_Cow 541
Stringing with TPU is pretty much inevitable, even with perfect settings. About the only way to prevent it is to avoid travels entirely 😕
The walls thing is a bit weird. If you could share your Cura project file (.3mf, get it set up then go to File > Save Project) so we could see all the settings you're using that might help.
