1.9? Anything less than 4 is a "pass".
So your noise level of the level sensor is good.
Pull the 2 cores out and compare the spring strength. If you hold the core by the black plastic only and push down the nozzle onto a table, is one much easier? Typically it is about 1kg of force needed (1000 grams on a food or postage scale).
Tenshidono 2
Correction: i figured out that the nozzle is supposed to move, my bad.
Edited by Tenshidonobut it normally stops after a small push instead of pushing the nozzle all the way inside.
Im guessing its an issue with the level sensors, but when i tried calibrating them the printer just told me i have a noise of 1.9
changed printhead to nozzle, i always get the two confused
