fbrc8-erin 316
Yes, it pre heats both cores as part of the active leveling in the firmware.
If I print a bucket load from one core, I usually put a BB core in the second slot without filament in the BB core for this very reason. The printer will not run with one core. I guess it adds too many edge cases in the softwareif one core can be missing.
We alternate print cores's use and usually ABS pieces suffers because of those cold-hot-cold-without-extrusions cycles, even with blob and extra brim.
Well I think it is what it is!
Thank you for your replies.
PizzaTijd 17
AFAIK it's just a prerequisite for the active leveling.
I have wondered about this as well, and have found this
