The top corners are being pulled inwards. The top flat area is creating a very strong pulling force pulling the top two corners towards the middle.
Let me back up. When you print PLA (not every plastic but most plastics), it comes out of the nozzle sticking to itself like snot - like a mucus. Like a liquid rubber band. As you lay in the top cover of that part it is pulling inwards because in the first few milliseconds after it comes out of the nozzle it's already shifting. So the problem starts where the top of that "box" is - just the last few mm of the part. This inward pull is very strong with that large surface area.
I don't know what the solution is exactly. Maybe less fan for the "top of the box" layers? Put the fan at 2%. Plus cover the printer? I'm not sure that will help much but getting the air inside the printer to 35 or 40C will help quite abit.
Normally one fixes this kind of thing with more support holding things in place but you don't really have any more space outside the part. It's a hack but you could design in having that top layer lean outwards a bit by about 3mm or whatever amount is shrinking. Is there room on the bed to move outwards another 3mm on each end (or whatever the shrinkage amount is)??
Another common solution that I assume won't work for you is to put lots of holes in that "top of the box" to reduce how much pulling force there is. But I assume you need that "air tight" as this looks like some kind of funnel.
It may seem crazy to add in printer shrinkage issues in your model but this is how they do it for injection molding - except usually the engineer who does the tweaking is located at the factory and is different engineer who designs the part. They even have to tweak 90 degree corners in injection molding to be at a different angle because they know corners will change by a few degrees.
Slashee_the_Cow 541
If you could share the Cura project file (.3mf, set it up then go to File > Save Project) so we can see your settings that would help.
Your problem isn't layer shift though, that's when one of the printer's motors skips a step or two and from that point on the rest of the print is out of alignment with what's already been printed.
It looks more like it's either ringing (which is an artefact from printing too fast) or your nozzle is partially clogged (so it can't always push out the right amount of filament).
