GregValiant 1,454
The tower is the model but it needs a little program called a "post-processor" to go through the gcode and add the temperature changes at the correct points in the print.
With the model loaded - go to "Extensions | Post Process | Modify Gcode" and then "Add a script". As you scroll down through the list you should come to "Temperature Tower". It should have installed when you loaded the Calibration Shapes plugin.
When you load it there are some new settings to fill in.
When the printer comes across an M104 or an M109 command; the screen on the printer should update to the new temperature. I'm guessing the gcode didn't have the constantly changing temperature lines in it.
Edited by GregValiant
nathandhittle 0
Turns out [maybe] it was changing the temp, just not updating the screen. I didn't have that option enabled in cura.
