I purchased a replacement fan and some 1w resistors and zeners to drop the voltage to the current level if needed. Actually, I got two fans in case I burn one and even a replacement transistor for the shield in case I smoke that too.
We'll see how it goes....
IRobertI 516
I added a second fan to my UM1 quite early on, it has been on there for at least a year, probably closer to two without any issues at all. The fan is a 12V Fractal Design FD-FAN-50. It's hooked up in parallel with the original.
