I mean if I slice the model in Netfab I can smoothly slide trough to check for parts of the model that need supports. That isn't possible in Cura because it's so slow, I move the slider and have to wait 4-5 seconds for anything to happen by which time it's jumped to a random point.
IRobertI 516
Not sure I understand your issue with the layer view. How can you check what the slices cura produces will look like in Netfabb? The layer view isn't showing a section view of the model, it's showing what the actual layers of plastic will look like based on the produced Gcode.
