How do I do two? If I try to add a new one it seems to only edited the custom1
- 2 weeks later...
Does anyone know how to add multiple custom filament settings on the U2? I can do it with my other printer easily using Repetier Host, but can't figure it out on my U2 =(
With the latest firmware this is what I did in the menu on the printer:
Material -> Settings -> Customize -> Change the settings to what you want them to be -> Store as preset -> New preset (or you can overwrite any of the old presets)
When you click on the last step it will return to the menu you were in previously so it looks like nothing happened. But if you back out of that menu and go back to the settings once more you'll find a new "CUSTOM X" at the bottom. I just tried to add a few and stopped at 5. You can't seem to rename them though.
- 1 year later...
I found you could rename them, by exporting to the SD card and editing the text file, then importing from the SD card.
IRobertI 503
I'm pretty sure you can add two entries. But no, you can't change their names at this time.
