GregValiant 1,251
There are standard "Profiles" like "Super Quality", "Dynamic Quality", "Standard Quality", and "Low Quality". Sometimes printer manufacturers will have slightly different names, but there will be a couple of standard settings profiles.
If you click on the name of the current setting profile options will appear at the bottom dialog. You can't over-write a standard profile but you can create your own from a standard profile. You can see that one options is to "Update Profile with current Settings/Overrides" that will allow you to update you custom profile to different values.
I have a a total of 5 settings profiles.
- TPU.
- PLA fast printing.
- PLA medium printing.
- PLA fine.
- PETG
I also have 3 Ender 3 Pro printers installed in Cura even though I only own the one printer. Each installed printer has a different StartUp Gcode. (There would be no way for me to print TPU purge lines at PLA speeds.)
If I have a fancy detailed model that I'm printing in PLA I choose the PLA printer and then the "PLA Fine" setting profile. I then go through EVERY SETTING and double check that it will give me the proper results for the particular model I'm slicing. What I will not do is update the profile because it is my "base" and I know it works. For example, just because I'm changing from normal supports to tree supports for this particular model doesn't mean I want tree supports turned on all the time.
Right now I'm printing a large flat plate with some raised lettering. There is a pause at height for the letters. I'm using the PLA Fast profile kicked up from 75 to 100mm/sec. When the letters start there is an M220 S50 line that will drop the print speed to 50% and that will be much more sane for fine work.
kennedyjm 0
Well that one did complete without any problems. The difficulty I have is that I don't know what settings it changed since there is no listing of Recommended settings.
