I agree. I recently stopped changing filament the "normal" way. Robert kept mentioning that he could push and pull filament through the UM2 feeder if the stepper was off and he's right - it doesn't really take much force at all - less than 1kg I think.
So my new procedure is to heat head to 90C to 120C region and when temp is around there I just pull it out!
Then I heat to 180C (or don't even bother with that) or so and push the new filament in. It's much faster also!
Sometimes I go to move filament (once the new filament is in) and spin the knob until the color changes or at least until it is primed.
Now I like this so much - I get to feel the resistance of the bowden with my hands. It's always good to have a feel for what might be causing "extruder skips" or other issues.
It's surprising but pretty much every time I go to do something like this the feeder motor is off. This is very convenient. I haven't had to cut power (to get the feeder stepper into an off state) yet.
IRobertI 517
Yup, I've been warning people about this for a long time, "good" to have someone agree with me finally hehe (although I've seen gr5 mention it a bit lately as well).
This is one of the reasons I designed my alternative feeder, to make swapping filaments easier. Being able to give the filament a good powerful tug when it has cooled down a bit means you get all of the old filament out in one go and when you put a new filament in you don't have to sit there and extrude for 3 minutes to make white PLA actually white.
However, I can't say that remaining strands in the bowden was ever a problem for me before. I always just loaded the new filament and those tiny strands would get pushed into a small "hair ball" and then get pushed down into the nozzle with the new PLA.
I noticed when doing the filament change procedure with the newest firmware (instead of manually like I usually do these days) that it pulled out quite slow at first and then sped up after a few cm were pulled out. I don't know what the logic is behind it. Pull out, let cool, speed up to break the strand that forms?
