:-P Hey, let's not hang your head. There is always support. :-P
I could for you, print a neck brace or something... :mrgreen:
Even with good things, it always takes some time until finally comes joy. :cool:
Markus
Markus
And yes gr5,
I think in my case I had found within the first three weeks of using the machine, the retraction lenght > 4.5mm (5.5mm) works generally better. :cool:
Did this at
210 / 60. 20mm/s No retraction.
From the above print, I feel that its too hot. So i set 195 / 40 cause I feel that everything is printing too near to the bed.
This round I print 2.
I think its not bad but what are causing those?
Those marks are oozing durign the pauses to retract and de-retract as it moves between the objects, i think. Have you tuned your retraction speed settings? I use 5.5mm at 35mm/s. Even higher speeds are possible with recent firmwares, and should be a good thing, but I haven't actually tried them.
High speed as of retraction speed or print speed?
Top Posters In This Topic
23
13
7
5
Popular Days
Apr 23
23
Apr 17
8
Apr 13
7
Apr 14
7
printedman 23 posts
gr5 13 posts
mnis 7 posts
illuminarti 5 posts
Popular Days
Apr 23 2014
Apr 17 2014
Apr 13 2014
Apr 14 2014
gr5 2,157
No. I can clearly hear the retraction occurring before it moves over to the side. The problem is that due to thermal expansion as the PLA heats from 20C to 220C and also existing pressure in the bowden (which should be zero due to the retraction).
Oh!!! I thought of one more thing! When I first got my UM2, I found retraction of 4.5mm was NOT ENOUGH. I had to go to 5.5mm and that was just enough. If you print something with mega retraction you can tell because you can watch the filament in the bowden and you can see it move up and down touching the top of the arc and then the bottom of the tube at the top of the arc. I could see that 4.5mm was not enough. Part of that extra 1mm was due to the bowden moving up and down on top of the print head.
But then later I rebuilt my print head such that the bowden doesn't move anymore. So now I use 4.5mm retraction.
