I have just tested it with Cura 14.01 and it is the same there.
I'd think you get better results by turning off combing, and just letting the printer retract properly on those moves.
Yes I can do that. Just wanted to highlight a possible bug in Cura.
Actually, these results are expected. The areas where no combing happens are so thin that combing would have a bad effect on the outside skin quality, as the nozzle would be traveling too close to it. So it retracts and travels. (You can see the retraction marks on the preview)
Sounds resonable. Thanks for the explanation Daid.
Dim3nsioneer 559
It's the same effect with 14.03-test2... Maybe combing moves are limited to a certain number of G0s? If it cannot be done within this number, it's just following a straight line?
