designsoul 18
Thanks, I may try that next time. For now I used a tiny drill bit on a dremel to drill bits off of the filament without trying to damage the tube. After about 10 minutes it came out.
gr5 2,097
I think your first solution to your first problem will work fine.
As for the second issue - If you put the bowden in boiling hot water (95C is plenty hot - it doesn't actually have to be boiling) then it will be easier to get the extra filament out. Actually 70C might be better so that you can use other PLA to push it out without having that melt also.
Maybe cut off a 4 foot piece of pla, put in freezer, then heat up bowden by dipping the bad spot in hot water, then wait 30 seconds, then remove bowden from water, remove 4 foot cold PLA and slide through quickly while the PLA in the tube is still soft?
I've never actually done this but other people have managed to get their PLA out of the bowden somehow.
