PS: is in 14.04 RC1 also the second filament diameter properly implemented?
Nope.
I'm actually working on making it possible to set almost all settings per nozzle. Which will make a lot more sense then implementing it per setting.
Nope.
@drayson: As we already are a bit off-topic: In (newer) Marlin, there is the possibility to define the filament diameter by an http://reprap.org/wiki/G-code#M200_-_Set_filament_diameter_.2F_Get_Endstop_Status per extruder (e.g. in the start.gcode).
This makes it necessary that the GCODE contains volumetric extrusion information. With Cura, you have two possibilities: either you use the new flavour 'RepRap (Volumetric)' which Daid has implemented in Cura some days ago and which will be in the next version or you set the diameter to 1.128mm which results in the same E-numbers.
Ah... Ok, thank you both for the update/hint. :-)
drayson 74
Daid, your THE man...
With this little fixes, you managed to safe my litte subnotebooks ass :smile:
All errors I reported in the 14.02/14.03... RC-posts are gone!
With this fallback, the 14.04. runs also on my old stuff without any error messages.
Now I can use the nice new features for support e.g. also for my dual printhead setup.
Thank you !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
