The bowden seems really solid at the push-fit connector at the hot end, and I've never noticed it moving on either end. This all happens on parts with no retraction as well so I don't think it's that. Any certain way to test this you can think of?
In the printing wizard in Cura the graph with the temperatures seems very stable, I'll grab a screenshot next time I give it another try.
I have disassembled the hotend recently and found no faults there, but I'll check it again and see is anythings funky.
When I read this out loud it seems the problem would have to be at the hotend though. The filament gets all chewed up so the feeder is trying. Maybe I'll try zip-tying my UBIS in there and see if I get any improvements.
Thanks for the suggestions
IRobertI 516
Have you checked that you don't have a partial bowden pop? If you do, that could be one possible explanation to why it works ok at first but then starts messing up later as more and more heat is transported upwards and makes the plastic at the junction point gooey.
Could also be worth checking for a partial clog in the nozzle.
Would also be an idea to check the temperature readings during the print. Perhaps there's a perfect storm of glitches that makes the temperature reading go wonky at some point causing underextrusion.
That said I had a somewhat similar issue with my printer way back. The first 1-1.5mm of print was always fine but after that it underextruded slightly. No matter what I did or what parts I replaced it just kept happening. Never figured that one out...
