Also check Xray view. If you see any red then there is a problem. Red indicates either internal walls or holes in the walls.
You can probably fix it in cad or you can just try out "fix horrible" "type A" in expert settings and it will probably include your "wedge".
IRobertI 516
How to upload pics:
http://umforum.ultimaker.com/index.php?/topic/4525-how-to-upload-an-image-to-the-forum/
In the mean time, always check the layer view after you have sliced an object to see if it looks ok. That way you save a lot of time. To switch to layerview click the big button on the top right and select "Layers". Note the progress at the bottom of the window, it might take a little while to render completely. And then you can scroll through the layers with the scroll bar on the right.
