Printer is not UM sorry, its a small i3 with triple extruder, the electronics are Rumba which has 3 extruder drivers plus XYZ so 6 in total.
Would be happy to modify the start2.gcode but when 3 extruders are selected then start2.gcode is ignored (this may be a bug?), did try add a start3.gcode to .ini file but is wiped out upon starting cura, this may not be the correct way to solve the issue, maybe start2.gcode should be called for more than 1 extruder (not just 2) and then could edit to my liking.
For now am just manually homing, primeing and setting temps etc before starting print, though it would be great to have start code to prime, eject other filaments etc (the 3 filaments share a single hotend) as no end2.gcode runs either to turn off motors or temps at completion of print.
drayson 74
Hmmm... How you connect the 3rd head to the UM elecrically???
I would just copy the start2 and modify it by myself...
