My Ultimaker consistently fails with a ~1cm plug blocking PLA feed.It happens sooner at high or low temperatures and faster x-y print speeds;
I could print a full 3mm over 2 hrs (Cura default settings; 25% speed) with nice-looking thread - then - basta!
I am unable to complete a single print job.
The print gear continues to work; the temperature of the nozzle holds constant - but a plug forms and feed is subsequently blocked
WHY?
and WHAT can I do to fix it?
EM
Have a look at http://wiki.ultimaker.com/Jamming
If you let your machine stand too hot for too long, heat will creep up the bowden tube. if you print too hot, liquid PLA will flow up the tube (back flow), also causing a plug. the goal is to print at the lowest acceptable temp for your current print speed (mm/sec) and layer thickness.
edgar-meyer 0
Huh?
Howzat?
