When using an aluminum bed you still put down a layer of tape or sometimes glass. Most people use an aluminum bed because they want to heat it so they switch from blue tape to polyimide tape. Both of these are electrical insulators. But for leveling, yes, you are correct that's a helpful trick. But you don't need the aluminum bed to do it. Check out this video:
-Matt
error1 0
With a conductive aluminum bed, wouldn't it be possible to hack the top Z end stop switch and solder one lead to the print head nozzle and another to the bed so that it triggers if the two touch? I haven't checked to see if the heating element and temperature probe are galvanically isolated from the nozzle metal but i think they are...
It would be a neat aid for leveling too! There would never be any question about where the absolute zero Z is
