I'm sure the model(s) are watertight, because I checked them many times and they were used for other purposes, so I can't understand were the problem is.
I checked the xray view : it's all ok. But when I look at "layers view" some layers (1 or 2) are missing and there is correspondance with the layers missing in the print.
I will do some photos and post them. In the meanwhile, if anyone experienced the same problem let me know. I'm looking for a solution.
Thanks
gr5 2,069
First of all never print anything without doing layer view first as you now know it saves you a wasted print.
I know you think it is "perfect/watertight" but this is certainly the most common issue (internal walls or holes). You can test it in Cura easily with XRAY view. If you see any red then there is a problem. Rotate all around the problem area.
A second reason for "not printing" is if walls are too thin. It would help if you posted a photo of the part in normal view and also layer view showing a problem layer.
To post pictures:
http://umforum.ultimaker.com/index.php?/topic/4525-how-to-upload-an-image-to-the-forum/
