Trouble making first print
kwatts
Posted · Trouble making first print
Hey Guys,
So i have gotten to the first print stage and am having some troubles.
Im currently working my way through this page:
http://wiki.ultimaker.com/Newcomer_guid ... t_3D_print
For software, since i am usning an old 32bit winxp i chose:
UltiReplicatorG-0024-r3-windows.zip from the software page.
now, it lets me connected to the printer, i have checked all the stops, in the NewComer_guide im up to
step 4 : generating the gcode.
in the software version i have , i can select skienforge 39 settings and not 40 that is in the docs.
if i edit any of the profiles, to the settings in the docs, and select "save all" and close the window, replicator g hangs. ie, i can see the select profile window, but i cant select anything. if i force close the repg program and reopen it the settings have saved to that profile.
So , i go to generate the gcode, which works, it , but it never allows my in the ui or the gcode menu to select "build"...
How do i proceed?
Or better yet whats the path to debugging what is going on here?
Cheers
Kym
