When you feed it in at the right angle you can feel it grab and start to pull. At the wrong angle it feels like it just stops.
If you just cant get the white tension roller to move out of the way as you push the filament in, you might try slightly loosening the four screws that hold the extruder on the back of the printer
SHOVE it in
You have to push harder, at first i was also concerned about this but just push harder and it will probably load well
Another thing you can do to ease the process is to cut the tip of the filament at an angle so that it is pointy. This shouldn't be needed but it makes it easier.
I had a very tough time at first loading the material, and I tried pushing harder but it wasn't the fix for me. Inside the feeder slot with the arrow there was a slight lip where the material was getting caught before it entered the chamber. While the feeder is spinning slowly, I would have to angle the material toward me so it didn't get caught on that invisible lip inside the feeder. Once I did this and the spinner reaches a certain point, the material would easily load. Took me a few tries to figure this out. If you're having trouble even after pushing harder, try wiggling the the material a bit inside that arrow labeled hole and see if it uncatches.
IRobertI 503
Did you give the filament a good shove? It's not enough to just hold the filament under there, you need to give it a good push.
