Some things to try:
1) Install the firmware I posted above
2) Adjust the extruder tension spring - If you're carving semi-circular divots out of the plastic, you probably need more tension; if you're just kind of flattening it out, then go for less tension.
3) Print the extrusion test piece to get a feel for the capacity of your extruder
4) Consider using less retractions, and printing slower/hotter.
5) Alternative feeders such as Robert's may be helpful.
Top Posters In This Topic
20
6
6
5
Popular Days
Jun 12
23
Jun 16
9
Jun 18
8
Jun 13
8
illuminarti 20 posts
Nicolinux 6 posts
selmo 6 posts
profepaco 5 posts
Popular Days
Jun 12 2014
Jun 16 2014
Jun 18 2014
Jun 13 2014
valcrow 144
I JUST got my UM2! yay!
Unfortunately I seem to be suffering from this as well.
When it prints, it prints wonderfully! But half the time, it's stopped extruding about 3mm into the print with the filament grinded down.
I read the thread but I'm not actually sure what the solution is... could someone clarify? Is it to install Robert's extruder? Use an earlier version of Cura? I'm on a stock new machine.
