unwanted hole
ultiarjan
Posted · unwanted hole
It seems you use a shell thickness of 1.6mm or similar. However, there is space for only three of the four lines. Maybe you try it with 1.2mm shell thickness. Before you print it, you could check it with layer view of Cura (which is always a good idea... ;-) ).
    Shell 1p6
    Shell 1p2
    thanks, you're right, in this case it's very visible when checking in Cura....
    however in the next model (nespresso cup holder) I find it very difficult to see in Cura what would be the best setting...
    nespresso shell 1p6
    nespresso shell 1p2
    For the nespresso shell, try setting infill to 100% and then check layer view to see if it adds a little bit more in the curves - I'm not sure if it will.
    The second print almost looks a bit like a classic "short belts too loose"-problem. Do circles come out as true circles for you?
    I thought the same thing but the gap is shown in layer view also. Plus he doesn't have the other typical features of backlash.
        • 9 replies
