Problem connecting with 0035
wout
Posted · Problem connecting with 0035
Yesterday I built my Ultimaker.
It was already printing very good but I had RepG 0024.
Today I installed 0035 but I can't get it to work.
I can select the serial port but when trying to connect I get en IOException (screenshot attached).
Next I tried to upload new firmware but RepG just ends up hanging.
I know it is supposed to but I waited for 30 minutes, no result.
I am new to this, not quite sure where to go next.
Can anyone help me on the way?
[uPDATE]
I can install the Old 5D firmware but none of the Sprinter/Marlin firmware.
    It seems that Erik broke that link somehow.
    What I would advice is this:
    - Disconnect the UM from your pc.
    - Start ReplicatorG
    - Connect the UM, but do NOT try to start it in replicatorG.
    - Upload the newest firmware on the board.
    - Go to Machine, Machine Driver and select Sprinter/Marlin.
    - Connect the machine in RepG.
    The upgrading can also be done with older versions, however repG 34+ requires Marlin firmware to work properly.
    EDIT: Cura firmware also works with RepG, but you need to use the "Experimental Marlin Firmware" in order to make it work.
    Thanks for your reply.
    In the meantime I managed to get the machine connected met the RC3 of Marlin (Erik's build).
    But I have not managed to get anything decent printed so far with 0035.
    Just now I went back to 0025, reinstalled the 5D firmware and I get very good results.
    Also it seems with 0035 the extruder is not working.
    At a given moment, while it was printing I could rotate the cog wheel of the extruder.
    It felt like the stepper motor was not connected.
    Ok, in the meantime I found a solution.
    0024 did allow me to install the new firmware.
    When that was done I could use 0035 to connect to the machine.
    I must say the quality of my prints improved tremendously.
