See here for my advice on how to reinsert the Bowden tube in the hot end...
As Robert says, once it's all assembled, the Bowden tube shouldn't move either up or down. It may be that the Bowden tube has been scraped by the retaining clip during the removal and reattachment process. If so, cut a few mm off the bottom of the tube, so that the retaining collet has fresh plastic to grip.
IRobertI 503
The flared edge will be at the feeder end if they're still doing that for the UM2. I know this was done on the original but I haven't actually checked it on the UM2.
First, is the "third fan" running? By third fan we mean the fan that is in the back of the print head. It should be running as soon as the printer is turned on.
When you removed the bowden tube, did it look like there were scrape marks or other damage around the area where the white collet is supposed to bite in and secure it in place? If there is damage you should cut off a small section of the tube so that the collet gets a fresh section to bite into (make sure the cut is straight). Also check that the small metal teeth inside the collet aren't clogged or damaged.
If everything looks good you can re-assemble. Undo the four bolts that holds the head together a few turns. Re-insert the bowden and make sure it sits all the way down into the white teflon piece. Put the little blue/red horse shoe back and then re-tighten the bolts. You'll see tube move up slightly as you tighten the bolts and if you tug at the tube there should be little to no movement up and down once you're done.
