gr5, to me, the long belt on the X axis is also twisting.
Looking at it closely, there does seem that the short belt might be touching the wood at the motor side pulley.
Guys thanks for your answers!
I am from UK. I am going to check and make the adjustment you suggested me.
I can already tell you that when I mounted my UM Original I replaced the black screws in the pulleys with the silvery/shiney and I had tighten those as much as possible. I also made markers on the rods for checking if they were moving during the printing but it was not happening.
I am going to change the alignment of the pulleys, I'll let you know how it goes.
Thanks!
Ok, we are getting better.
In this picture the object at the top is the last one I printed, the one at the bottom is the correct one that I printed two months ago before the arising problem. It's still not rounded but it's better than the black ones and others that I printed in the meanwhile.
- I added the washers to the screws of the X motor and now the short belt is not twisting and is not touching the wall
- I moved also the pulleys on the rod connected to the x motor and I think the long belts are not twisting too
- my long belts are also loose and the sound that I can hear is similar to the one in Erik's video
- the sudden shift that has happened with the big model was probably caused by gcode weirdness as you said and as was my concern that that model was not correctly designed
- your point 3, gr5: here we are. I am not able to move very easily the header with one finger in each block. The thing is that I have never been able to do it, even when I was printing properly well. However the movement on the X axis is less smoother than when I push the block on the Y axis.
Probably the problem is here, but I am sure the pulleys are aligned. My concern is that the wood panels of the headers are not perpendicular each others and I need to dismount the extruder. Do you think it is the case?
Thanks a lot for your help!
Then the motor must have missed steps. It takes a lot of friction for the motor to miss steps.
I don't know where your friction is coming from but you need to experiment with power off until you find it.
Hi Gr5,
I did experiment with the power off, moving the head by hand and I need to force this movement,it's not happening easiky.
I saw in videos that people can move the blocks with fingers without any pressure but it has never been my case.
After I built the printer, I had been in contact with Official Customer Support of Ultimaker and they told me that since the printer was working fine anyway, it wasn't so a big deal.
Indeed it has worked fine since that episode with that big model,even without smooth movement of the header and with the short belt touching the wood panel.
After the episode, I dismounted pulleys,rods, X motor, I made all the changes suggested me but there are still problems:
-I didn't experience missed steps or sudden shift, but I printed just that small object in the picture
-however it doesn't print rounded objects correctly
- the short belt doesn't touch the wood panel anymore
- the belts, both short and long, do not twist
- the pulleys are aligned and tighted to the rods
- the movement of the header is still not smooth but I need to force it
My concern is that there is something damaged or broken, I don't know a bent axis?
Anyway thanks a lot for your support Gr5, I submitted a ticket last 18 june to Ultimaker support, I updated the situation, but I am still waiting an answer from them.
while you are waiting, you can try lubricating the rods with a light oil like sewing machine oil. NOTE: DO NOT USE GREASE LIKE THAT USED ON THE Z SCREW.
On my UM1, this GREATLY reduces the force required to move the head and is recommended by UM as printer maintenance.
I didn't see if you'd checked the end caps over the axis rods? If those are screwed too tightly, they can stop the rods rotating as they need to.
You might also need to square up the cross-rods through the head. To do that, undo diagonally opposite pulleys on one of the axes. E.g., front-left and back right, on the x axes. This allows the two long belts around those axes to move independently of one another. Move the head all the way to the back, making sure both sides of the cross rods are an equal distance from the pulleys. Then tighten the front pulley back up. Move the head all the way to the front, making sure its still square, and tighten the back pulley. Then repeat for the other pair of axes. You might also need to loosen the tensioner/screw in the sliding blocks, to make sure that the cross rods are fully seated - if they aren't you can end up with the exposed part of the cross rod being too long - and that can also push things out of square.
gr5 2,094
I had only watched the second video when I posted above. Watching the first video...
I see that the X stepper belt is definitely twisting. So even though it doesn't look like it's touching the wood - it is. Take that stepper out and make sure the pulley is as close to the motor as possible without touching (.5mm is good) and then add the 4 washers (one for each screw) under the plastic spacers that I mentioned above. Afterwards you will see the X short belt is no longer twisting. And you will get lass black powder below it.
