I really like the human readable comments in the Simplify3D gcode ... all settings are in there.
I wonder what info is readable from CURA, if you set your machine to RepRap/Marlin you get to set the start and end code in CURA , This is easy to use for UM2 as wel. Just make some changes to the start code (include priming etc)
http://umforum.ultimaker.com/index.php?/topic/10075-ulti-evening-march-23rd/?p=103183
If I look in this start code I see stuff like
;Print time: {print_time}, I wonder if there are more parameters not currently used available ....
Anyhow, maybe not worth it to spend to much time on this as "pink unicorn" will probably make it useless again ...
Top Posters In This Topic
112
33
29
29
Popular Days
Jan 1
13
Nov 23
11
Dec 31
9
Dec 30
8
tinkergnome 112 posts
ultiarjan 33 posts
rigs 29 posts
gpb01 29 posts
Popular Days
Jan 1 2015
Nov 23 2015
Dec 31 2014
Dec 30 2014
Popular Posts
chiz
Yup, it's the first run wizard. Ok, I'll try it and let you know what happens. Thanks a lot! Update: You're right! I need to complete the first run wizard first. After installing cust
Posted Images
tinkergnome 927
Let's see...
The informations for (estimated) printing time and material length are read from the comments at the top of the gcode file (only for UltiGCode-flavor AFAIK).
Displaying the time in another format (incl. minutes) should be easy.
The Cura profile is a different challenge...
It is embedded at the end of the gcode in an encoded format. Due to the very limited RAM available at the Arduino board - decoding and parsing of the Cura profile would be... ... ... not so easy...
Perhaps a better approach:
Someone... could write a Cura plugin that includes the major profile informations as comments at the top of the file.
The same might work for progress informations. Basically the end-position of the E-axis is needed. I guess, the firmware could calculate the progress and the estimated printing time more accurate just by comparing the current E-axis position to the last position...
Mmmhhh - or a more general approach...
how long would it take to parse the whole file at the beginning (without printing) and track the max. positions...? I think this is worth a test...
