Yeah it looks like the nozzle is a little high, although hard to tell properly with the PLA everywhere. Once the nozzle is a little hot, give it a quick wipe with a wet rag or paper towel and make sure its as clean as possible. Sometimes when the pla starts to exit the nozzle it can twist up a bit too, kind of sticking to the nozzle, so as the print starts watch out for this, and if it looks like its not flowing straight down grab it with your fingers and give it a bit of direction Keep playing, you`ll get there in the end!
gr5 1,877
well it looks a bit high (meaning nozzle too far from glass). Start printing and just turn the screws counter clockwise while it is printing just to see what happens.
There is a bug in Marlin that is fixed in the absolute latest cura that you can download that fixes 2 bugs related to leveling. Or you can just never level again and only play with the 3 screws.
having it wad up on the nozzle isn't a disaster but it should stick flat to the glass.
Other things to try:
heat glass to any temp from 45C to 65C. Clean the glass with a glass cleaner. put a think coat of glue stick on the glass. But the glue shouldn't be mandatory just to get the first layer to look good.
