The back/third fan is hardwired to power so it cannot be disabled in firmware unfortunately. On future versions of the PCB this feature will be added.
And, the firmware change for this has already been added. (Sadly, the first prototypes of this new board had a problem with the motor drivers, so it will take a bit longer before it's rolled out). But once this new board is in new machines this feature gets activated automatically.
Our electronics guy also proposed to note down a small schematic so people could wire this up themselves if they want. We still have spare pins in the board that could be used for this. (It should just be a transistor and a few resistors)
IRobertI 502
However, the fan shouldn't be noisy so I would contact Ultimaker and see if they can send a replacement to you. Changing the fan yourself is fairly straight forward.
