"after this, therefore because of this"
You might be jumping to conclusions a bit. Cura has been calculating everything already for quite some time every time you press a key (way before 14.03). It doesn't need to wait, as the calculating is done in a seperate process with the lowest priority. Your operating system will scale this automatically.
DidierKlein 726
No it's not possible.
Try maybe to set the settings with no object on the buildplate?
