A few question I need answered too if somebody would help
bob-hepple
Posted · A few question I need answered too if somebody would help
Hi
I have three questions that need help with.
1 I downloaded the latest version of cura and along with it the latest Firware upgrade for um2. Do I need to re do the bed levelling procedure before I print. I have kept the old v of cura in another location.
2 the tweak at z there is 2 input fields where you can change the temp / speed one is with height which would be awkward for me or there is layer number? Now is this the slider on the right where you view layers is this the layer number.
3 and last I have read some post about the efficiency of the fans and in some cases people have printed there own cowlings
https://www.youmagine.com/designs/fanduct-another-idea#!design-documents
Do these represent a significant advantage especially when printing with overhangs
Thanks
Bob
    1. You shouldn't need to re-level.
    2. Yes, the slider shows the layer numbers
    3. Don't know as I haven't experimented with those on the UM2. I know it made quite a difference for me on the original though.
