Sure Didier, go ahead and do that but I figured since the guide is in English those who only visit the French section would have much use for it.
Regarding the Atomic description. That was created before I joined the team but the thinking behind it is to make sure that all the material is melted regardless of type. Say you have printed with ABS and a bit of residue is left in the hotend, or if some material from the feeder has made it in there and so on. And since you only heat it up and then immediately let it cool down again I don't think it should be a problem. It's not like you're letting it sit there to cook for 10 minutes.
Labern 772
Thanks a lot Robert
THIS is really great stuff and I'm sure I will learn a lot from it.
Great for newbies like me
